medastar
Newbie level 6
- Joined
- Jul 3, 2013
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 78
here is my code,and i was expect 500hz from the formula of
Crystal Frequency
PWM Freq = ----------------------------------------- but i couldnt found what i want can anyone help me where is the error pls.
(PR2 + 1) * (Timer2 Prescaler) * 4
#include<18F4431.h>
#fuses INTRC, NOWDT, NOPROTECT, NOBROWNOUT, NOPUT, NOLVP,NOMCLR
#use delay(clock=8000000)
#define POWER_PWM_PERIOD 1999
void main()
float x =1;
setup_timer_2(T2_DIV_BY_16, 249, 1); // 500 Hz PWM freq with 8 MHz osc
// Setup the 4 Power PWM channels as ordinary pwm channels.
//setup_power_pwm_pins(PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON);
setup_power_pwm_pins(PWM_COMPLEMENTARY,PWM_COMPLEMENTARY,PWM_COMPLEMENTARY,PWM_COMPLEMENTARY);
// Mode = Free Run
// Postscale = 2 (1-16) Timebase output postscaler
// TimeBase = 0 (0-65355) Initial value of PWM Timebase
// Period = 154 (0-4095) Max value of PWM TimeBase
// Compare = 0 (Timebase value for special event trigger)
// Compare Postscale = 1 (Postscaler for Compare value)
// Dead Time
setup_power_pwm(PWM_FREE_RUN, 1, 0, POWER_PWM_PERIOD, 0, 1,0);
output_toggle(PIN_D1);
while(1)
x =0.50;
set_power_pwm0_duty((int16)((POWER_PWM_PERIOD *4) * x)); // 50%
set_power_pwm2_duty((int16)((POWER_PWM_PERIOD *4) * x)); // 50%
delay_ms(500);
Crystal Frequency
#include<18F4431.h>
void main()
float x =1;
// Mode = Free Run
// Dead Time
while(1)
x =0.50;
delay_ms(500);
