walters
Advanced Member level 2
When looking at schematics of bias resistors of transistor stages how do u find out the voltages for each "node"?
Whats the easiest way to find out the voltages for each NODE in any stage or section of a circuit or schematic?
Most Schematics don't tell what the voltages are at each stage/section or node/point of a circuit
What would do the easiest way to find out or get these voltages?
What shortcut formulas or tech experience to find out "voltage drops" for bias resistors of transistor stages?
RULES:
1.) The collector bias resistor voltage should be "HALF" of the power supply voltage?
2.) The Base bias resistor voltage should be a 3/4 of the power supply voltage?
3.) The emitter bias resistor voltage should be 1/4 of the power supply voltage?
RULES:
