zoorahk
Newbie level 1
Hello:
I have been working on a paired transistor PNP, NPN amp for a primary square wave signal. I have looked at the specifications in the data sheets but it does not make since to me. I am assuming that there is a minimum volt, amp or watt threshold for every transistor before it starts operating. I would call it a "trip threshold" but I can't make heads or tails of the terminology. Can you tell me what spec in the data sheets refers to the point at which a transistor starts doing it's job? Or is there a formula I need to calculate what I need to know?
Thank you,
Zoorahk
Thank you,
Zoorahk
