Hi ,
Recently i developed a wireless sensor node to which i three analog sensors and one solid state relay.
Here i attached the figure of it
Power Requirements of MCU
Supply Voltage 2.7 - 3.6 V
Transmit Current (Typ@3.3V) 80mA
Idle/Receive Current (Typ@3.3V) 20mA
Power-down Current (Typ@3.3V) 1.6uA
Sensors power requirements
1.Soil moisture sensor 5VDC and 7mA current
2.Soil temperature sensor 5VDC and 3mA current
3. LM-35 5VDC and 60uA current
4.SOLID STATE RELAY 5Vdc and 15mA current
I used two LDO ic for 3.3v and 5.5vDC
3.3VDC and max 800mA is used for powering th MCU.
And 5VDC and max 800mA is used for powering sensors connected at the connectors and there supply is controlled by BC109 Transistor with 3.3v base voltage through MCU port pins.
Battery specifications
Using 6 in number 1.5vDC Duracell AA battery for hen added all the six is 9VDC but according to the model number on it MN1500 i found that it is capable of 2.850AH
Here i even attached the circuit diagram of it
could any one please help to calculate them and eve the procedure
