Thanks for the answers. I did some research and did this calculation:
circumference of the spool: diameter of the screw * PI :: 1 * 3,14 = 3,14
Length of wire: Number of turns * circumference :: 500 * 3,14 = 1570 cm
The resistance of the wire / cm (ohm): 0,00032
Total resistance of the wire: resistance per cm * length :: 0,00032 * 1570 = 0,5024
Current: I = V/R, I = 5 / 0,5024 = 9,95 A
Im using wikipedia to get information about the copperwire:
https://en.wikipedia.org/wiki/American_wire_gauge#Tables_of_AWG_wire_sizes
Two questions reagarding the cable:
1) The Ampacity - is that what temperature the current will generate? In my case than if you read the table, since my current is 9,95 A that would generate about 70 degrees? Is that correct?
2) Fusing Current - that is the current that will melt the wire? Preece is longer than 10 seconds and Onderdonk is over 1 second or 32 ms? Is that correct?
Im also using a diode to handle the EMF
So in my case I should go for a thicker wire (lower AWG) to be able to take down the heat .
Then to calculate the magentism I use this page:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html
Solenoid Magnetic Field Calculation
here I get with my values: 157 m long, 500 turns, 9,95 A in current and 200 in relative permeability = 79.64 gauss in the center of the magnet
So in my example above I will get:
heating about 70 degrees
In other words I will go for a thicker wire to get down the heating ...
Would you agree on this calculation?
Thanks
