i have made my model in cadfeko and checked my results..can i run this file in edit feko to get same results?? r i need to make my model in edit feko itself???
PLZ reply asap..
You only need EDITFEKO if you need to make advanced changes/settings to the model. For example in EDITFEKO you can use for loops and if statements to e.g. frequency dependent loads. You can build the geometry in EDITFEKO if you want, but it really isn't necessary!
