Cadence tutorial on Monte Carlo simulation
cmosbjt
Full Member level 5
USA
I used to use ADS. Now I need to do monte carlo simulation in Cadence. ADS has very good way to manifulate data. But I don't know how is it done in Cadence. How to write expression? Where can I find reading materials about that?
cadence monte carlo tutorial
u can find good know from www.cic2.edu.tw and sourcelink.cadence.com
crete.cadence.com
all cadence university program websites from all universities
better go thro crete.cadence.com
it will help u more
cadence monte carlo simulations
Thanks. Actually before I use ADS, I used Cadence for a while, but only some basic operations. I know how to draw schematic in Composor, layout in Virtuoso and simulate using Artist. After I used ADS, I notice that I need the flexibility to manipulate the simulation result data. In cadence, there are many functions and conventions doing this job, that is what I want to know.
cadence tutorial monte carlo
Cadence usually comes with lots of help pdfs. I think you can find them in the installation directory.
I think you need to read the help of the Cadence calculator and that of SpectreRF.
cadence calculatror tutorial
elbadry tell about CDSDOC files
if u have install cadence run cdsdoc command u will get all help information.
if u need more tutorials i will upload here
cadence tutorial
for example, I want to do monte carlo simulation to check the gain variation of my LNA. How to set the "Expression/Signal" field?
cadence monte carlos analysis tutorial
Assuming you are familiar with using the calculator, open the calculator and get expression from the calculator.
cadence calculator
let's say i set the sp frequency sweep simulation, from the calculator i press the S21 button and get the expression of "aas(2 1)", I "Get Expression" to the Statistical Analysis above. However after simulation the waveform can not be display.
cadence calculator s21
can u tell me how to use the calculator in the cadence
monte carlo tutorial cadence
maybe you can read the help files of the software, it's the tutorial.
tutorial on cadence waveform calculator usage
From Analog environment, Open Tools >> Calculator... >> use functions inside to make expressions as u like
Hope that helps..
Regards,
Ahmd,
