Cadence Tools on Linux RHEL3, using SATA harddisk
jenkoh
Newbie level 2
mkdefcfg failed
I installed RHEL 3 into xw6200 (SATA Harddisk) and I could not launch the projmgr (SPB15.2), but I have no problem using nclaunch (IUS5.5) its works fine.
I also installed RHEL 3 update 5 into xw8200 (SCSI Harddisk) and face no problem launching projmgr but encounter
1) when issue projmgr command, this error msg appears
'error while loading shared libraries: libc.so.6: cannot open shared file: no such file or directory'
2) when creating new project, this pop-up error msg appears
'mkdefcfg failed on creating expand.cfg file for cfg_package'
3) when i click on the setup, design entry this error msg appears
'error while loading shared libraries: libdl.so.2: cannot open shared file: no such file or directory'
Does anyone knows how to fix this problems?
Does the type of harddisk (IDE, SCSI or SATA) affects the EDA tools?
Thanks a million in advance
regards
jennifer
cadence mkdefcfg failed
hi
i think it is not the problem of SATA HDD. if RHEL is installed correctly without problems then softwares should run fine
regards
Jenkoh,
check if this env.var can help you:
export LD_ASSUME_KERNEL=2.4.1
Type it in the terminal window before starting the program, or put it in your .bashrc file.
Bye,
maranaza
check this libdl.so.2 and libc.so.6 if in your LD_LIBRARY_PATH.
I had checked that two files in your /lib,if your installation is correct.
