Cadence Skill question RE: Analog Design Environment
turdturtle
Newbie level 3
Does anyone know how to add a Skill-created GUI component (ie pulldown menu) to the menu of ADE ?
Something like:
hiCreatePulldownMenu(         'myMenu
         "myMenu"
         list( myItem )
      ) ;hiCreatePulldownMenu
      hiInsertBannerMenu(hiGetCurrentWindow() 'myMenu 99)
but instead of "hiGetCurrentWindow()", how do you specify you want ADE ?
I'm loading this in .cdsinit so that every new ADE window will have my custom menu.
Thanks!
I think you've got the wrong section...
Anyway, put your command in a procedure,
e.g.:
procedure( UserSchMenu()
          "myMenu"
          list( myItem )
) ;proc
Then, put a trigger for the procedure to load,
e.g.:
deRegUserTriggers("analogArtist-schematic" nil nil 'UserSchMenu)
Check more in the documentation on how to use this SKILL command.
A good place I know to post SKILL questions is at:
https://groups.google.com/group/comp.cad.cadence
Best regards
    turdturtle
Thanks very much -- it was very helpful.
I have one final bug (or mistake etc):
It now says (after I load the skill code with my ADE session up and going):
*Error* User post install trigger is not a symbol
Do you know how to solve this?
EDIT: Shoot shoot, stupid typo. Thanks alot!!! -- it worked just fine.
In the future, I'll be trying to add custom menu's to stuff other than ADE -- do you know how to figure out the viewtype name of windows ? Ie how do you figure out that the ADE window is analogArtist-schematic ?
Thanks!
Ok, another question: How to handle passing parameters to callbacks?
ie :
hiCreateAppForm( blah blah ?callback 'myCallBackFunc )
procedure (myCallBackFunc( a b c) ) ; proc
How to pass params to callback from "hiCreateAppForm" thing?
Thanks!
It's easier to use:
hiCreateAppForm( blah blah ?callback "myCallBackFunc( param1 param2)")
Save the commands in a file & use load("......") in .cdsinit.
Best regards.
