I hope you have all necessary settings in your cshrc file, now if you do which ncsim in your terminal make sure it returns IUS installation path, to work with simulator type just type ncsim <arg1> <arg2>... ; BTW which version are you using?
Therse are three methods to start ncsim:
1. Three steps for terminal
ncvlog *.v
ncelab top_module_name (-nc_options)
ncsim top_module_name (-nc_options)
2. one step for terminal
ncverilog *.v (+nc_options)
3. The easiest way to start ncsim is by GUI.
nclaunch &
You just need to have the correct settings for the path etc. The following shell variables should be set in the manner described below:
setenv PATH <path_to_ius_installation>/tools/bin:$PATH
setenv LD_LIBRARY_PATH <path_to_ius_installation>/tools/lib
setenv CDS_INST_DIR <path_to_ius_installation>
As Sudip mentioned if you do which ncsim, it should show the path to the ncsim binary. You can use the commands given above or you can use
irun command for single step execution of the simulation. "-gui" option can be used for launching the GUI.
