Cadence IC5141 spectre error with neoCircuit
okguy
Full Member level 6
China
cadence ic5141 spectre
When I try to get the output within Neocircuit, I always got the following error :
... even if I use the two-stage-opamp of the demo.
I have no more idea how to serach the error :cry:
Thanks for your help !!!
OkGuy
____________________________________________________________________
error: Spectre error during run
While evaluating temp on host ******* (Mon Sep 19 07:53:07 CST 2005)
[Linux ******** 2.6.9-5.EL #1 Wed Jan 5 19:22:18 EST 2005 i686 i686 i386 GNU/Linux]
Simulator output:
cpp: unrecognized option `-$'
spectre (ver. 5.10.41.052404 -- 24 May 2004).
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA
Security, Inc.
Simulating `netlist.final' on ******** at 7:53:01 AM, Mon Sep 19,
2005.
Error found by spectre during circuit read-in.
"netlist.final" 5: Syntax error in specification of `spectre//'.
"netlist.final" 7: There can be at most one global statement and, if
present, it must be the first command in the file (after title or
language directive).
spectre terminated prematurely due to fatal error.
...(See 'Eval Errors' panel for full text of error message.)
cadence neocircuit
I have same problem. please help me.
Re: cadence ic5141 spectre
OkGuy
Simulator output:
Security, Inc.
2005.
The error is because the c++ compiler is not installed at the initial installation or c++ version is old.
Anyway, the developmnet package including the compiler can be installed by using "Install Package".
