saikatchatrg
Newbie level 2
I am working on a standard cell library designed by me using Cadence Virtuoso. I am using Spectre for netlist generation. Now I am trying to characterize the library using Encounter Library Characterizer(ELC). But I am not able to move ahead. It stars with the database 1st. in the command file, I am using the following command.
db_open cds.lib
db_prepare -f
db_spice -s spectre -keep_log -keep_wave
db_output -p typical -alf test.alf -lib test.lib
db_close
exit
But it is not able to recognise the library.
my elccfg file is as follows.
#Specify the environment variable settings to use for characterization.
EC_SIM_USE_LSF=1;
EC_SIM_LSF_CMD="";
EC_SIM_LSF_PARALLEL=10;
EC_SIM_TYPE="spectre";
EC_SIM_NAME="spectre";
EC_IGN_XTG=1;
EC_CHAR="ECSM-TIMING ECSM-POWER";
#Specify the characterization inputs.
SUBCKT="input.scs";
MODEL="model.scs";
DESIGNS="INV_X1";
SETUP="setup.default";
PROCESS="typical";
LIB="SUBVT28CORE";
Though the cds.lib file contains the path for SUBVT28CORE library which is the library here I am working on; the tool says that it can not find out the design INV_X1.
I will appreciate any kind of help.
Regards
Saikat Chatterjee
db_open cds.lib
db_prepare -f
db_close
exit
EC_SIM_USE_LSF=1;
EC_SIM_LSF_CMD="";
EC_IGN_XTG=1;
SUBCKT="input.scs";
MODEL="model.scs";
DESIGNS="INV_X1";
PROCESS="typical";
LIB="SUBVT28CORE";
Regards
Saikat Chatterjee
