cadence analog design environment cant plot current
irfansyah
New South Wales
cadence plot current
i cant make cadence analog design environment to plot current of any instances except a dc voltage source. this is a bit annoying, does anyone know what's going wrong?
here's the error message on icfb window:
*Warning* Wave10 is not a waveform object that can be displayed and
          will be turned OFF automatically.
          expr: "IT(\"/I4/OUT\"
          \"/home/irfansyah/cadence/simulation/clc3/spectre/schematic\")"
Thank you.
cadence simulation plot current
Go to Outputs -> save all in Analog Environment. Then select currents: selected or all. The current should plot after that.
plot current cadence simulation
In addition to jasgar's thing, if you are interested in AC currents you have to check the save AC terminal currents button.
my problem is that i cannot plot transistor node currents. current flowing through voltage source nodes are no problem, they are fine.
apparently i still have to do it the old annoying way: add a dc voltage source for current measurement.
Re: cadence plot current
Thank you.
irfansyah, I think I have run into the same problem with you, did you solve this?
Thanks.
