jiawenyin
Newbie level 2
Can some one help me, I want to use cadence AMS to sim my circuit,
netlist, compile and elaborate are success, but in SimVision (Done) windown, the error creates like this :
Fatal error found by spectre
you don't have permission to run Virtuoso(R) Spectre(R) circuit simulator
please see the attached file.
If I run only analog circuit with Spectre, the Spectre simulator works well.
If you also encounter same problem, please give some help.
I don't know this is the cadence license problem or environment configuration problem.
Thank you.
Thank you.
