Cadence AMS - connect rules
atamez
Newbie level 6
amsconnectlibcompile
update - i found the library connect_lib and amsConnectLibCompile, and I believe I have installed the new library correctly.
However, now during elaboration I get the following error:
ncelab: *E,CUVNCM (../SAR_cap_array/test_adc_ahdl/schematic/verilog.vams,91|57): No connection module found:Need an input port of discrete discipline logic, and an output port
of continuous discipline voltage.
sample_out ), .vrefpcontp( vrefpcontp[11:0] ), .dout( dout[11:0] ) );
In the elaboration options I have tried connectrules module 'mixedsignal' and 'connrules_18V_basic'. Each of these modules declares an elect2logic, logic2elec, and bidir connect rule - so I do not understand why the elaborator is unable to work.
I can post the connect modules if necessary, but they are the ones that came with the kit - $LDV_DIR/tools/affirma_ams/etc/connect_lib
Still will appreciate any input however. Thanks!
DenisMark
Full Member level 6
Russia
verilog.vams
I had same problem when I studied ams-simulation with ams-designer. I don't know correct solution till, but i did so.
1. Create lib, ex. "amsLib"
2. Create cellviews for e2l and l2e connect modules in the lib ("symbol" and "verilogams" views)
3. Create cellview for connect rules module in the lib ( "verilogams" view). Name it as 'mixedsignal'
4. Give link to 'mixedsignal' in elaborator
Good luck
Reactions: horzon
    horzon
atamez
Newbie level 6
cadence ams tutorial
Thanks for your input. I did find the connect library and was able to compile it. It was in $LDV_INST_DIR/tools/affirma_ams/etc.
My question now is in regards to compiled verilog-ams code. There are some standard digital cells that came with my kit, and I was using their cmos_sch views in spectre. During netlisting AMS created verilog.vams views for these cells.
Now during elaboration I'm getting errors (see original message), and it doesn't like the transistor instances. So, my question is, in verilog-ams what is the correct way to instantiate MOS devices?
DenisMark
Full Member level 6
Russia
verilog-ams library_binding
I don't remember. U can look for Cadence documentation (for ex. verilogamsref).
atamez
Newbie level 6
discrete discipline logic cadence
I've been wandering through the cadence documentation (cdsdoc) for a while, but just can't find exactly what I'm looking for. I've also been following the AMS tutorial with limited success. Thanks though for your reply.
DenisMark
Full Member level 6
Russia
ncelab e cuvncm
Try type "nchelp ncelab SPPBYN" in console for detailed help. (I try it, but it isn't work in LDV5.0).
    atamez
atamez
Newbie level 6
ams compile connect rule
Now I think we're getting somewhere
[ 182 ] % -: nchelp ncelab SPPBYN
nchelp: 05.40-p004: (c) Copyright 1995-2004 Cadence Design Systems, Inc.
ncelab/SPPBYN =
Spectre and spice primitives may only have ports connected by order.
Ok, so in short if my MOS device has four ports (g, s, d, b) I need to create instantiations without the .g(x) .s(y) .d(z) .b(/gnd!) convention. I will search for a netlisting or compilation option that describes this.
Thanks!
DenisMark
Full Member level 6
Russia
connect rules in verilog
I use IC5.1.41 & LDV5.0, part of netlist for primitives looks like
resistor #(.r(1K)) (* integer library_binding = "analogLib"; *) R0
( NETZ9, cds_globals.\gnd! );
I don't know where u can change netlister options (u have newer version i see). Verify CDF properties of instances from "cmos090" lib, may it helps u.
    atamez
datone520
Junior Member level 3
China
can you say clearly about the correct way to instantiate MOS devices??atamez??thanks
datone520
China
Re: cadence ams tutorial
do you have more idea about this question?your sharing will be apprieated
