What average do you want to do ?Now I would like to take average of the 10 points for each temp corner
and plot them against the temp itself. e.g. "temp vs. mc_mean_val".
Measurement value x is dependent on two values, temp and mc_trial.
x(temp, mc_trial), total, temp*mc_trial
Show me OCEAN-XL Script."I do a monte-carlo for some points setting a fixed temperature
and getting a mean value from summary table.
I repeat this with many temperature points
and plotting that mean value on y-axis and temperature on x-axis"
You set temperature as corner condition.
Sweep temperature as parameter instead.
;====================== Set to XL mode =========================================
ocnSetXLMode()
ocnxlProjectDir( "--" )
ocnxlTargetCellView( "----" )
ocnxlResultsLocation( "" )
ocnxlSimResultsLocation( "" )
;====================== Tests setup ============================================
;---------- Test " " -------------
ocnxlBeginTest(" ")
simulator( 'spectre )
design( " ")
path( " " )
modelFile(
'(" " "tt_lib")
'(" "pre_simu")
definitionFile(
" /model/models.scs"
analysis('xf ?start "1m" ?stop "1G" ?p "/bgBufP"
?n "/bgBufN" )
analysis('tran ?stop "1m" ?errpreset "conservative" )
analysis('dc ?saveOppoint t )
desVar( "chop" 1 )
desVar( "AZ" 0 )
desVar( "selbuff" 1 )
desVar( "selgain2" 1 )
desVar( "bgAdjsel" 4 )
desVar( "f_chop" "1M/512" )
desVar( "c_load" 500f )
desVar( "iref0" 10u )
desVar( "iref1" 5u )
desVar( "iref2" 5u )
desVar( "iref3" 5u )
desVar( "vd" 5 )
desVar( "vs" 0 )
desVar( "maxacfreq" 10.1M )
envOption(
'analysisOrder list("dc" "xf" "noise" "pss" "pnoise" "psp" "pxf" "pstb" "pac" "tran" "pz" "dcmatch" "stb" "envlp" "ac" "lf" "sp" "qpss" "qpac" "qpnoise" "qpxf" "qpsp" "hb" "hbac" "hbnoise" "sens" "acmatch")
option( 'temp ""
option( ?categ 'turboOpts
'uniMode "APS"
temp( "" )
ocnxlOutputExpr( "(VDC("/vbgP") - VDC("/vbgN"))" ?name "vbg_dc" ?plot t ?save t)
ocnxlOutputExpr( "value(getData("/out" ?result "noise") 1)" ?name "noise_spot_@_1Hz ")
ocnxlOutputExpr( "(VDC("/bgBufP") - VDC("/bgBufN"))" ?name "buf_dc" ?plot t ?save t)
ocnxlOutputExpr( "(sqrt(integ((getData("out" ?result "pnoise")**2) 1 (0.9 * VAR("f_chop")))) / 1.4)" ?name "pnoise_integ_@_f_chop")
ocnxlOutputExpr( "value(getData("/out" ?result "pnoise") 1)" ?name "pnoise_spot_@_1Hz ")
ocnxlOutputExpr( "(-1 * db(getData("/V0" ?result "xf")))" ?name "psrr_curve")
ocnxlOutputExpr( "(sqrt(integ((getData("out" ?result "noise")**2) 1 (0.9 * VAR("f_chop")))) / 1.4)" ?name "noise_integ_@_f_chop")
ocnxlOutputExpr( "average((vtime('tran "/vbgP") - vtime('tran "/vbgN")))" ?name "vbg_tranAvg" ?plot t ?save t)
ocnxlOutputExpr( "value((-1 * db(getData("/V0" ?result "xf"))) 0.01)" ?name "psrr_dc" ?plot t ?save t)
ocnxlOutputExpr( "average((vtime('tran "/bgBufP") - vtime('tran "//bgBufN")))" ?name "buf_tranAvg" ?plot t ?save t)
ocnxlEndTest() ; "playground_tb:study_p2004_noise_tb:1"
;====================== Sweeps setup ===========================================
ocnxlSweepVar("AZ" "1")
ocnxlSweepVar("Chop" "1")
ocnxlSweepVar("selbuff" "1")
ocnxlSweepVar("selgain2" "1")
ocnxlSweepVar("bgAdjsel" "4")
ocnxlSweepVar("f_chop" "1M/512")
ocnxlSweepVar("c_load" "500f")
ocnxlSweepVar("iref0" "10u")
ocnxlSweepVar("iref1" "5u")
ocnxlSweepVar("iref2" "5u")
ocnxlSweepVar("iref3" "5u")
ocnxlSweepVar("vd" "5")
ocnxlSweepVar("vs" "0")
ocnxlSweepVar("maxacfreq" "11M")
ocnxlSweepVar("chop" "1")
;====================== Model Group setup ==========================================
;====================== Corners setup ==========================================
ocnxlCorner( "tt_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""tt_lib"")
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""pre_simu"")
("modelGroup" "")
ocnxlCorner( "ss_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""ss_lib"")
("modelGroup" "")
ocnxlCorner( "ff_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""ff_lib"")
("modelGroup" "")
ocnxlCorner( "fs_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""fs_lib"")
("modelGroup" "")
ocnxlCorner( "sf_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""sf_lib"")
("modelGroup" "")
ocnxlCorner( "mc_pre"
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""mc_lib"")
("modelGroup" "")
ocnxlCorner( "mismatch_pre"
("variable" "temperature" "-40:5:190")
("model" "/home/dagtech/tsmc/tsmc_0.18/BCD/spice_model/T-018-CV-SP-018/rev1.6/T-018-CV-SP-018/models/c018bcd_gen2_v1d6_usage.scs" ?section ""mismatch_lib"")
("modelGroup" "")
;====================== Test v/s corners setup =================================
;====================== Job setup ==============================================
ocnxlJobSetup( '(
"blockemail" "1"
"configuretimeout" "300"
"distributionmethod" "Local"
"lingertimeout" "300"
"maxjobs" "1"
"name" "ADE XL Default"
"preemptivestart" "1"
"reconfigureimmediately" "1"
"runtimeout" "-1"
"showerrorwhenretrying" "1"
"showoutputlogerror" "0"
"startmaxjobsimmed" "1"
"starttimeout" "300"
"usesameprocess" "1"
;====================== Disabled items =========================================
ocnxlDisableCorner("tt_pre")
ocnxlDisableCorner("ss_pre")
ocnxlDisableCorner("ff_pre")
ocnxlDisableCorner("fs_pre")
ocnxlDisableCorner("sf_pre")
ocnxlDisableCorner("mc_pre")
;====================== Run Mode Options ======================================
ocnxlMonteCarloOptions( ?mcMethod "mismatch" ?mcNumPoints "10" ?mcNumBins "" ?mcStopEarly "0" ?mcStopMethod "Significance Test" ?samplingMode "random" ?saveProcess "1" ?saveMismatch "1" ?useReference "0" ?donominal "0" ?saveAllPlots "0" ?monteCarloSeed "" ?mcStartingRunNumber "" ?dumpParamMode "yes" )
;====================== Starting Point Info ======================================
;====================== Run command ============================================
ocnxlRun( ?mode 'monteCarlo ?nominalCornerEnabled nil ?allCornersEnabled t ?allSweepsEnabled t)
ocnxlOutputSummary(?yieldSummary t ?exprSummary nil ?specSummary nil ?detailed nil)
ocnxlOpenResults()
;====================== End XL Mode command ===================================
ocnxlEndXLMode()
No.Probably I did the same way you suggest.
Don't do.Providing temperature on Corner and then sweeping them creating multiple corners.
No.Monte Carlo simulation does not support variable sweep.
No.
It is not a limitation of Monte Carlo simulation.
It is a limitation of ADE-XL.
If you can write OCEAN or OCEAN-XL, you can do anythig.
Yes you can.Is there anyway to run that OCEAN script apart from ADE-XL? (e.g. from terminal or anywhere?)
Yes you can.
From CIW or Unix prompt.
I use Unix prompt.
BTW can you use ADE-Explorer(=Maestro) ?
ocean.What is the command to run it from Linux terminal?
You can not understand anything at all.Even running Ocean-XL from CIW window has the same issue.
