I‘m a student majoring in EE. I want to design a wide-band high-efficiency rectifier for wireless power transmission based on the paper below. I used the same diode as it said: HSMS286c in HFDiode lib. I used the variable 'f' to simulate the Zin in different frequencies. However, the verdict is different from the paper's result and I have no idea why. The imag part is positive but it should be negative. Perhaps I set something wrongly.
-You do a methodology error.Don't use LSSP, instead use HB and place Current Meter at the input and simply divide V/I ( complex impedance) because rectifiers are highly nonlinear systems.
-The author used a tunable source impedance and you should imitate the same thing.
The paper's title is Shaoyong Zheng's Design of an Ultra-Wideband High-Efficiency Rectifier for Wireless Power Transmission and Harvesting Applications.
Hi, I'm new to ADS and I'm puzzled right now. I think the tunable source impedance means matching network which I can only add after measuring the Zin. Can I still use this source? I wanted to change it into AC power, however, this paper never mentioned the Vin or Iin, I only know Pin is 17dBm. To be more clear, the proposed rectifier in this paper is attached as follows. Thank you so much for answering my questions.
Thanks a lot, I get it. Did I set the input right? And could you tell me how to calculate Vin/Iin, please? I'm really confused. Thank you so much for your help!!!
