cable tester circuit diagram
hossam abdo
Full Member level 2
Alexandria, Egypt, Egypt
Dear all
I need a circuit diagram for a two conductor shielded cable
thanks in advance
goldsmith
Advanced Member level 5
Tehran - IRAN
Hello dear hossam abdo
What do you need accurately?
Do you want a circuit that can tell you that is the cable intact or not ? isn't it ?
Best Wishes
Goldsmith
goldsmith
Tehran - IRAN
Well
You can use 3 buzzer with 3 transistor , and the bases are test probes and the power supply is common pin. or with 3 LED and a battery you can do it simply.
Good luck
Goldsmith
hossam abdo
Full Member level 2
the cable is too long(more than 20m) and constructed at fixed places
i need to make a device with two part to be free to check it
