Thanks for the help. I need to simulate Belden 1694A up to 600 meters. The error should be within +/-1 dB up to 6GHz. Do you have any recommended document about this topic?
You can possibly simulate the attenuation characteristic, but not the delay and respectively not the reflections. Also crosstalk and common mode characteristic are effectively out of reach.
Depending on the test purpose, it's better to use a real cable.
Thanks a lot to both FvM and volker@muehlhaus. You two are right, it is difficult to make a simulator matching to real cable with amplitude, phase and returnloss in the same time.
I have manage to make a simulator up to 3GHz for 100m Belden 1694A with 10 realistic components. Refer to the attached pictures for simulated performance.
The purpose of making the simulator is to do automatic production testing of SDI transceivers. Real cable roll will be
too big and heavy. I have constructed the 100m/3GHz simulator on testing board. The attenuation curve matches well with the simulation and we can use it for the testing
