C6713 DSK, windows Vista, CCS 3.1 connection problem
bigreat
Member level 1
vista ccs
HI, I just received the C6713 DSK, and I installed the CCS 3.1, drivers from the coming CD.
However, I connected the DSK board to my laptop (VISTA OS) via USB, and ran 6713 DSK Diagnostics Utility v3.1.
It said:
Starting diagnostic test suite.
--> Running USB diagnostics.
Can't connect to target.
• ** Plug in power and USB cable.
• ** Can't run if Code Composer or Diagnostic already running.
Result> USB diagnostic fail
Stopping diagnostic suite.
What's wrong...?
Thank you!
c6713 dsk vista
there are many more reasons to occur such error ... kindly check ur usb cable and power first ... if step 1 is true then test ur dsp board on another pc ... if step2 is true ... check whether ccs is installed properly on ur pc.
ccs 3.1 vista
I have the same problem. In fact, my DSK is working properly with P4 computer; but the problem is with the Core (2) Duo computers, whether the OS is XP or Vista.
I think we have to ask TI about this problem.
Regards,
Dr. Ahmed
ccs vista
I made it works on Vista (core 2).
Very simple, just run the driver and CSS in compatible model.
ahmedseu,
I'm actually a starter of C6713, and I need to use it for a school's project. If I meet some problems, may i contact you?
Thank you
texas instruments code composer studio 6713 vista
I hope you would tell me how to run the driver and CSS in compatible model?
Best Rregards
Ahmed
Re: ccs vista
ahmedseu,
Thank you
Hi bigreat, I know it's a very old thread but I am experiencing the similar problem now. I tried to install both in compatible mode already, and thankfully I can make the diagnostic tool work.
However I couldn't make the CCS works. Is it true that we have to uninstall it thoroughly and get a fresh installation first to get it works?
Thanks a bunch! :D
