C question - floating point initialization
LBdgWgt
Member level 5
Hello,
For example i have this type of union data:
typedef union {
unsigned long int my_long;
float my_float;
double my_double;
unsigned int my_word[2];
unsigned char my_byte[4];
} mydata;
how can i initialize a variable declared in mydata type with floating point value?
I am writing a code for HCS12 using ICC12
this code line doesn't work when i chek in the .lst file
mydata data1 = {1.25};
results in:
0404 _data::
0404 00000001 .word 0,1
is this the problem of the compiler or...?
thanks for any answer.
You would have to have a constant data variables in order to be able to initialize them.
Yuo need a const union in rom
actually this data will be implemented inside EEPROM (not Flash program memory), so i want to generate a floating point initialization value.
so what should i do?
If you put a value in the float variable in your union, all the variables in the union would get the same value.
You need a rom struct
const rom struct {
float my_float;
double my_double;
} mydata;
initialize all the variables to what you want.
bu you won't be able to change them in the code run time, they would be constant
Added after 5 minutes:
even a better way:
declare your structure first:
struct mydataStruct
float my_float;
double my_double;
then...
initialise it:
const rom struct mydataStruct mydata[5] = { put values here separated by a comma };
To initialize a variable declared in mydata type with floating point value you must use this:
mydata data1.my_float = 1.25;
Regards, svicent
Regards, svicent
That is not an initialization.
That is a statement.
In "The C programming language", you can read:
"A union may only be initialized with a value of the type of its first member. "
This code line works OK
if you define:
typedef union {
float my_float;
double my_double;
} mydata;
Regards, svicent
    LBdgWgt
