C Program to Convert Binary Number to Decimal PIC18F4520
qlouis76
Malaysia
Beginner here for C Programming.
Basically using MPlab to work on my C program.
Some problem, with input binary number using 4-sliding switch to PIC18F4520 (PortB. RB0 RB1 RB2 RB3). :-(
Am I suppose to write the program for each bit for each port to convert binary to decimal?
Need some help and suggestion.
Thank you :)
which compiler you are using?
No.
you can do something like this,
unsigned int number[8] = {0,1,2,3,4,5,6,7};
void DELAY_ACTUATE()
a = (input_b() & 0b11111111);
decimal_value = number[a];
Best wishes :)
No.
Best wishes :)
Thank you.
I am using C18 C compiler.
I am beginner. it is like this
void main ()
TRISBbit.TRISB4=1
unsigned int number[4] = {0,1,2,3,4}; //only 4 bit (1111) so maximum is 15 in decimal.
a = (input_b() & 0b1111);
Correct me if I am wrong. Is C program will know example (1001 is 9 )?
I am sorry still learning.
If the 1001 is suffixed by 0b then it will indicate the compiler that the number following is a binary number.
void main ()
TRISBbit.TRISB4=1
is this correct?
