ben_IC
Newbie level 3
- Joined
- Feb 7, 2014
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 33
Hello,
I have designed a circuit in Cadence Orcad. I need to have a model of this circuit in Matlab or C for further analysis and modeling of the entire system.
I have a good model for the entire system except two transistors that operate as a common source amplifier. There is a P FET that operates as a load, and an n FET that is driven by a signal. I have used MbreakN-X and MbreakP-X and right now I use a Level 3 spice model for them.
How can I get a very good model for this two transistors? What Ids/Vgs equations should I use? I know that basic Ids/Vgs equations in introductory VLSI books are not precise enough. Is there any C++ or Matlab m files for transistor modeling for this level?
I am very flexible on what spice model, which technology, or which level I use. The only important thing is that I need a spice model WITH readily available and easy to use equations for it so that I can simply put in C or Matlab and they give me similiar results.
Thanks in advance
B
Thanks in advance
B
