C language problem - I'm getting compiling error
JoKKeR
Full Member level 2
Estonia
C language problem
Hi !
Im using function(s) before declaration. That is the reason im getting compiling error.
On the other hand reason why im using such program build is, that i like to keep things logical, at least on math level ( scientific equations).
So are there any techniques how to solve a problem im having ?
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
double L = 59.10; // latitude
double declination () //declination 583 539 87
       double d;
       d = declination(); //declination();
       double N = 0;
       N = 100;
       d = 23.45 * sin (360 / 365 * (284 + N)) ;
       return d;
    // d = declination
    //N = day number, January 1 = day 1
double hour_angle () // Hour angle
       double Al;
       Al = altitude_angle() ;
       double L = L;
       double D;
       D = declination() ;
       double H = 0;
       double elev = 0;
       H = acos ( -1 * (sin (L) * sin (D) - sin (-0.8333 - 0.0347 *(sqrt (elev) ))) / (cos (L) * cos (D))) ;
       //H = cos-1[-1 * (sin (L) * sin (D) - sin (-0.8333 - 0.0347 (sqrt (elev)))) / (cos (L) * cos (D))] ;
    //Al = Solar altitude angle
    //L = Latitude (negative for Southern Hemisphere)
    //D = Declination (negative for Southern Hemisphere)
    //H = Hour angle
double altitude_angle () // Altidue angle
       double Al = 0;
       double L = L;
       double D;
       D = declination() ;
       double H ;
       H = hour_angle() ;
       //sin(Al) =( cos(L) * cos(D) * cos(H)) + ( sin(L) * sin(D) ) ;
       Al =sin(( cos(L) * cos(D) * cos(H)) + ( sin(L) * sin(D) )) ;
    //H = Hour angle
double azimuth_angle()
       double Az = 0;
       double Al;
       double L = L;
       double D;
       D = declination() ;
       //cos (Az) = (sin (Al) * sin (L) - sin (D)) / (cos (Al) * cos (L)) ;
        Az = cos((sin (Al) * sin (L) - sin (D)) / (cos (Al) * cos (L))) ;
    //Az = Solar azimuth angle
double EOT () // Equation of time
       double N = 100;
       double B = 0;
       double E = 0;
       B = (360 * (N - 81)) / 365;
       E = (9.87 * sin(2*B)) - (7.53 * cos(B)) - (1.5 * sin(B));
       return E;
int main()
  system("PAUSE");
  return 0;
Thank you !
Added after 2 minutes:
BTW. The location of problem is between 2 or 3
function.
The variable Hour angle keep recurring .
Re: C language problem
The first function is recursive, it calls itself? A recursive function must have a termination state, I can not see one?
It gets worse!
The function 'hour_angle()' calls 'altitude_angle()' , which calls 'hour_angle()',
double recusion? And they both call the recursive function 'declination()'.
I wouldnt be surprised to see a wiff of smoke arise from the computer that tries to run this program.
    JoKKeR
concerning the order of functions use forward declaration:
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
// forward declaration of functions
double declination ();
double hour_angle ();
double altitude_angle ();
double azimuth_angle();
double EOT ();
       double d;
       double N = 0;
       N = 100;
       return d;
    // d = declination
but it doesn't solve the problem with recursive functions that btbass mentioned...
    JoKKeR
C language problem
Thank you for really good replies !
I guess my skill level is way basic, i need to gain more experience. cmon i worked on this code for a day ... there are actually pone number in comments ;)
Ill try to re build whole thing, since i do not have much experience ... Can i have some advice how to combine many equations and link them to time resolution effect like thing.
Thank you !
C language problem
What is d = declination() supposed to do other than put the program into a non-terminating loop and have the stack go rampaging through program memory until you get an 'out of memory' message? Also, I hope you realize that C programs start with main(), and not the first function defined in the source code, because your main() does nothing. It is probably a good practice to give all functions in a file a forward declaration, it makes the code more readable. Or better yet, put them in a header file and #include it at the top of the file.
