c++ language for AVR?
7rots51
intitle:c++ language inurl:viewtopic
Hi
If we use C/C++ IAR compiler for AVR.
What is the advantage of using c++ object oriented programming for AVR embedded designs?Can it solve some problems easily that is difficult to solve with C?Does c++ reduces the number of program lines?
what is your experience? :?
Regards
avr c oop
In my oppinion (but i'm not speaking out of experience with C++ in AVR) it's dangerous to use C++ for uC's. I guess the biggest problem is Memory allocation! You need to keep track of the memory you use since it's probably limited.
I also think code size is a bit bigger (after compilation, perhaps you can write smaller code) but this is an assumption.
I think if you're gonna use operator overloading, templates, streams, Inheritance with virtual functions, ... you have to have a good idea of what your doing. (If there is a C++ compiler for AVR that supports these things) Small memories are probably the biggest enemy of Object Oriented design.
For the moment i try use only a subset of the C standard library for AVR, eg not the scanf or sprintf methods since they increase compiled code size allot (3 to 5 kB)
Antharax
scanf iar avr
a couple of months ago I started with AVR and c++. It's rather painful adventure, but now most of things seems to work. So I decided to share my little experience, maybe it will be useful for you.
object oriented avr
stevejack have you tried C++ coding for AVR in IAR compiler?
Why would C++ be more memory intensive than C? It works exactly like C when compiled so the difference would be close to none.
Also, why would memory allocation be a bigger problem in C++ than it is in C? After all newlib uses the same procedures to allocate memory with C++ as it does in C. You can use stack allocation in C++ too despite it being rather limiting.
Simon
