[SOLVED] C# interface to a wifi module connected to a PIC
itlok
how to create a windows form in c# which send and recieve data from and to a wifi module connected to a PIC. i've been searching for tutorial but with no luck. thanks!
there are a number of posts dealing with WiFi modules and PICs, e.g.
https://www.edaboard.com/threads/325241/
what device are you talking too and what protocol are you planning to use?
for example, devices such as Microchip's RN171
https://www.microchip.com/wwwproducts/Devices.aspx?product=RN171
support TCP and UDP protocols - you can write a server in C# and connect the device to it
https://msdn.microsoft.com/en-us/library/c19ex43h(v=vs.110).aspx
https://www.codeproject.com/Articles/2614/Testing-TCP-and-UDP-socket-servers-using-C-and-NET
Reactions: itlok
    itlok
im using HLK-wifi-mo3 for the wifi module and PIC18f4550.
if you do a web search for HLK-wifi-mo3 you will find plenty of links
you should be able to connect it to a TCP or UDP server running on your PC
Reactions: itlok
    itlok
