rkt_167
Junior Member level 1
- Joined
- Aug 9, 2013
- Messages
- 19
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 3
- Activity points
- 163
hi all,
I have build a GUI to capture packet through Ethernet and to implement this I have used Pcap.net libraries but If capturing starts it goes on until and unless I stop debugging.
Question:
So I want to stop this during the execution of program by using a button and also I should be able to start it again??
I want to tell that I searched and I found that we can do that by using communicator.break(); but HOW??
Here is My code:
thanks
Question:
Here is My code:
Code C# - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 IList<LivePacketDevice> allDevices = LivePacketDevice.AllLocalMachine; int deviceIndex = 0; while (deviceIndex == 0) { //Console.WriteLine("Enter the interface number (1-" + allDevices.Count + "):"); string deviceIndexString = box.Text; if ((cmbInterfaces.Text == "") || (deviceIndexString == "")) { MessageBox.Show("Select an Interface to capture the packets AND Enter its Number", "**PLEASE ENTER**", MessageBoxButtons.OK, MessageBoxIcon.Error); return; } if (!int.TryParse(deviceIndexString, out deviceIndex) || deviceIndex < 1 || deviceIndex > allDevices.Count) { deviceIndex = 0; } }; // Take the selected adapter // Retrieve the device list from the local machine PacketDevice selectedDevice = allDevices[deviceIndex - 1]; // Open the device using (PacketCommunicator communicator = selectedDevice.Open(65536, // portion of the packet to capture // 65536 guarantees that the whole packet will be captured on all the link layers PacketDeviceOpenAttributes.Promiscuous, // promiscuous mode 1000)) // read timeout { // Check the link layer. We support only Ethernet for simplicity. { if (communicator.DataLink.Kind != DataLinkKind.Ethernet) { Console.WriteLine("This program works only on Ethernet networks."); return; } } // Compile the filter // using (BerkeleyPacketFilter filter = communicator.CreateFilter("ip and tcp")) // { // Set the filter // communicator.SetFilter(filter); // } Console.WriteLine("Listening on " + selectedDevice.Description + "..."); // start the capture communicator.ReceivePackets(0, PacketHandler);
thanks
