zakkos
Newbie level 6
- Joined
- Jan 17, 2013
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,439
hello all, I have a new problem here.
I'm still learning C for PIC (xc8 compiler) and as a beginner project i'm doing a thermometer with the popular ds18b20 and a pic16f628 i had lying around.
My program does behave good when it is allowed to run but while i was playing with pointers, structures, arrays etc. to return more than one value in a function i noticed something went haywire and now the PC goes back and forth not allowing the program to run sequentially. I'm quite sure I have forgot something about program and/or memory locations but i can't figure out what or why. Can someone help me? What's the best way to share the whole main code plus includes files here for you to examine it? for now i just paste the main code...
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 /* * File: termometro.c * Author: zakkos * Created on April 18, 2013, 2:20 PM * * / /*ESSENTIAL DEFINITIONS*/ #define _XTAL_FREQ 4000000 /*INCLUSIONS*/ #include <xc.h> #include <stdio.h> #include <stdlib.h> #include <lcd.h> #include <1-wire.h> /*CONFIG PRAGMA*/ #pragma config BOREN = OFF, CPD = OFF, FOSC = INTOSCIO, MCLRE = OFF, WDTE = OFF, CP = OFF, LVP = OFF, PWRTE = ON //typedef unsigned char uint8_t; void read_temp(void); union { char eratura; char decimali; }temps; int main(void) { INTCON = 0x00; PIE1 = 0x00; CMCON = 0x07; //disabilito i comparatori - disable comparators TRISA = 0x00; PORTA = 0x00; TRISB = 0x00; PORTB = 0x00; const char decims[16] = {0, 0, 1, 1, 2, 3, 3, 4, 5, 5, 6, 6, 7, 8, 8, 9}; char temp; lcd_init(); lcd_send_cmd(LCD_CLR); lcd_send_cmd(LCD_HOME); writeString("Hello,"); lcd_send_cmd(LCD_LN2); writeString("World!"); __delay_ms(1000); while(1) { read_temp(); lcd_send_cmd(LCD_CLR); lcd_send_cmd(LCD_HOME); writeString("Temp:"); lcd_send_cmd(LCD_LN2); if((temps.eratura & 0x80)){ //if sign bit is set temps.eratura = ~temps.eratura; //2's complement temps.eratura += 1; temps.decimali = ~temps.decimali; //2's complement temps.decimali += 1; lcd_send_dat(0x2D); //minus } temp = (temps.eratura/100)& 0x0F; //centinaia 157/100=1 (hundreds) if(temp){ lcd_send_dat(0x30 | temp); temp = ((temps.eratura/10)%10) & 0x0F; //decine 157/10=15%10=5 (tens if hundreds is set, meaning it will display also a 0) lcd_send_dat(0x30 | temp); } else { temp = ((temps.eratura/10)%10) & 0x0F; //decine 157/10=15%10=5 (tens if hundreds is no set, meaning it will not display if 0) if(temp){lcd_send_dat(0x30 | temp); } } lcd_send_dat(0x30 | (temps.eratura%10)& 0x0F); //unita 157%10=7 (ones) lcd_send_dat(0x2E); //dot lcd_send_dat(0x30 | decims[temps.decimali] & 0x0F); //decimals lcd_send_dat(0xDF); //degrees } } void read_temp(void){ char scratchpad[9]; while(ow_reset()); ow_write_byte(0xCC); ow_write_byte(0x44); while(ow_read_bit()==0); __delay_ms(1); while(ow_reset()); ow_write_byte(0xCC); ow_write_byte(0xBE); for(char k=0;k<10;k++){ scratchpad[k] = ow_read_byte(); } temps.decimali = scratchpad[0] & 0x0F; temps.eratura = (scratchpad[1] << 4)|(scratchpad[0] >> 4); return; }
