C Compiler for Atmega8515
smartsarath2003
Member level 4
c complier for atmega8515
Hai,
I am a newbie with little experience of Atmel AVR's. So far I only worked out with assembler and a very little exp. of WINAVR. I am developing test module and I wan to use proffessional C-compiler.
One of the problems I had with winavr in the past is lack of documentation and built-in functions. Because I want to make the code re-usable to many test modules,I prefer to use a good c-compiler with debugging options.
Can any one suggest me a nice c-compiler that can be used with AVR's.
8O
Thanks
Smartsarath2003
atmega8515 projects
what dont you find in avrlib are available in others ?
atmega8515 studio 4
Best c complier for Avr is Iar Embedded Workbench Pro For Atmel Avr.
www.iar.com. Price is about 3000$US
avr gcc for atmega8515
h**p://hubbard.engr.scu.edu/embedded/avr/avrlib/
I did downloaded AVRLIB. It looks like it works like a function library header only from another application
it contains headers and source files together . Look either for installation instruction or when using functions from library simply add header and source files to your projects .
avrlib is written for winavr (avr gcc) . But you can adapt it to any compiler .
