Register Log in
Button debounce tips?
ltg
Member level 4
button debounce
Can anybody give me a smart button debounce algorithm without using time delays? Thanks!
Best regards,
ltg
ME
debounce button
For which MCU and which language, C or assembler?
Reactions: keeloq
    keeloq
ltg
Member level 4
pic debounce
Sorry for unclear information. It for 8-bit and 16-bit MCU and in language C.
Best Regards,
ltg
cozturk
debounce in c
I use it by detecting DTMF tones. kt3170.. and 16f84..
It is not important long press or short presss for any time:
for example:
loop:
if button=0 then loop
if button=1
pause 50ms
loop2:
if button=1 ?
goto loop2
end
C-Man
button debouncing
If you are using interrupts simply read your button(s) periodically (for example 50 times per second).
All you have to do is take the last button state, compare it to the current button state and if anything has changed report it to your main program and keep the current button state as last button state.
hope this helps
bogdanm
debounce c
If you want something different, take a look at a smart routine here:
hxxp://www.dattalo.com/technical/software/pic/debounce.html
echo47
Advanced Member level 5
USA
debounce algorithm
I agree with C-Man. In most applications, the simplest solution is to sample the button at a steady rate. Use a D-flop and clock, or a software timer interrupt. I usually set the sampling period to be at least twice the worst-case bounce duration. If the button bounces 10 ms, I'll set the clock to 50 Hz.
luben111
Advanced Member level 1
UK
how to debounce a button
Hello,
I'm using RTOS and never had such problems. The task that scans the keyboard, wakes up every 10-20ms and read the key status. If there is toggle 1-0 I report key pressed. Using RTOS is very easy to build "long press" buttons, where you can change the functionality of the same key - fast press - INC/DEC, long press - ENTER.
Trust me, for keys and buttons scan RTOS is one excellent solution.
While the task is waiting (10-20ms) other tasks continue working. The whole project becomes very reliable, with smooth operation.
Best regards
Luben
