kakoee
Newbie level 3
Bus routing
I have a design containing two softmacros. there is a bus
between them. I want to route the whole bus together in a
automatic way, but not using interactive route tool, as I
want that tool decide the path of the bus and insert buffers along the route if it necessary to meet timing. However, when I
try the bus signals using route_group each bit of the bus is
routed in a different shape and different path. How can I ask ICC that route the whole bus together in a same shape and same path.
The situation becomes very worse when signals of the bus
need buffers to meet timing, and bus signals are scattered
around.
around.
