amandeep_pec
Newbie level 6
I am trying to build a small circuit using Analog Devices AD9240 Analog to Digital Convertor. I am giving supply voltages of (+5=AVdd) to the ADC. However, as soon as I connect the supply to the ADC a smoke starts to come from AVDD pin, and on testing it using a multimeter it starts showing a resistance of 1-2ohms between AVDD and ground. I have tried to test the same on around 7-8 ADCs bt am facing the same problem each and every time. I also tried to just connect the ADC and not interface it with ny of the components in the system, but I face the same problem.
Any help would be appreciated
Thanks a lot,
Regards,
Thanks a lot,
Regards,
