Verilognoob1
Newbie level 3
- Joined
- Dec 8, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 56
Hello:
I'm having trouble starting this project which is building a special type of an elevator, I'm planning on using FSM and maybe behavioral, but behavioral will be really hard.. I kind of started building one using the FSM with a topelevel module, controller module, datapath module, and a slowclock module to implement it on the FPGA... I will post the requirements here in addition to my attempt ( my attempt is failing really bad when I try to implement it on FPGA using xilinx, so many error and warnings) any ideas and help editing would be appreciated it ....oh and I'm using Digilent BASYS2 FPGA board, I'm coding this project using Verilog on Modelsim, then flashing the fpga using Xilinx tools...
requirement of this special elevator:
The purpose of the Elevator Control System is to send an elevator to the correct floor to carry Zoompa
Boompa’s, the affectionate name for Billy’s highly-skilled workers, to the two key locations in the
chocolate factory where they make Billy’s famous candies - Floor #1 and Floor #4. Zoompa Boompas
may use slides at their discretion to go to lower floors whenever they wish.
There are four floors in the chocolate factory. Zoompa Boompa’s pressing the Floor #1 button will be
taken to Floor #4, the top floor. Zoompa Boompa’s pressing the Floor #4 button will be taken to the
bottom floor. If a Zoompa Boompa presses the Floor #2 or Floor #3 button, then they must go in the
current direction of travel of the elevator, taking them to either Floor #1 or Floor #4. So, unlike a normal
elevator, there is only one button per floor.
It takes 2-seconds to travel from one floor to the next. This must be simulated as part of your final
solution.
Oh … and one more thing. Billy Zonka has a “prefix code” - a special combination of switches that, if
thrown properly, blast the elevator out of the Chocolate Factory. The Prefix Code for this elevator is
1011. If four special switches (to be defined next) are set in this specific arrangement, then the Elevator
is instantaneously shot into the atmosphere and may only be reset to Floor #1 upon throwing a reset
button.
On your BASYS2 board you are to utilize the following buttons, switches, and LEDs:
* SW7 is your Elevator Reset Button. It should remain high when in active use, and toggling it low, then
high, resets the entire elevator control system (including placing the elevator back on Floor #1 if blasted
into space).
* SW3, SW2, SW1, and SW0 contain the Prefix Code Setting. If set to 1011 at any point during normal
operation, then the elevator ejects itself from the building.
* BTN3, BTN2, BTN1, and BTN0 represent the push buttons on Floors #1, #2, #3, and #4 respectively.
* LD3, LD2, LD1, and LD0 represent the four floors, #1 - #4, respectively, and are an indicator of where
the elevator is. So, if the elevator is on Floor #1, and a Zoompa Boompa presses the Floor #4 button,
the LD3 LED should turn off instantly, the LD2 LED should be on for 2-seconds, turn off, then the LD1
button should be on for 2-seconds, etc.
* If the elevator goes to Floor #1 or Floor #4 and has no queued push button requests on any floors,
then it should just remain at rest.
* If the elevator is traveling up, then the 7-segment display digit on the far right of the board should
display a “U”. If the elevator is traveling down, then the 7-segment display should display a “D”. If it is
not traveling at all, it should display a “-“. The other three displays should be off at all times.
* If the elevator is out of the factory due to the Prefix Code being set properly, then LD3, LD2, LD1, and
LD0 should ALL be on, and the 7-segment display should display a “-“.
my attempt:
toplevel
controller
datapath
slowclock
solution.
button.
into space).
my attempt:
toplevel
module toplevel (sevseg, segout, L1, L2, L3, L4, clock_2Hz, f1, f2, f3, f4, a, b, c, d, clock_50MHz, reset, direc, rest);
output wire L1, L2, L3, L4, clock_2Hz, f1, f2, f3, f4, direc, rest;
input wire a, b, c, d, clock_50MHz, reset;
//input wire [3:0] prefix;
output wire [0:6] sevseg, segout;
controller I1 (f1, f2, f3, f4, segout, a, b, c, d, clock_2Hz, reset, direc, rest, prefix);
datapath I2 (L1, L2, L3, L4, sevseg, f1, f2, f3, f4, segout, clock_2Hz, reset);
slowclock I3 (clock_2Hz, clock_50MHz, reset);
endmodule
controller
module controller (f1, f2, f3, f4, segout, a, b, c, d, clock_2Hz, reset, direc, rest, prefix);
output reg f1, f2, f3, f4;
input wire a, b, c, d, clock_2Hz, reset;
output reg direc, rest;
output reg [0:6] segout;
reg [2:0] presentState, nextState; // TO BE DONE STILL: (NOTES TO ME)
// ADD PREFIX CODE
// NEXT STATE DETERMINATION FOR ALL FLOORS
// FIGURE OUT ERROR: Multi-source in Unit <controller> on signal <nextState<3>>; this signal is connected to multiple drivers.
// FIGURE OUT ERROR: "toplevel_toplevel.v" line 44: Invalid use of input signal <prefix> as target.
parameter floor_1 = 2'b00;
parameter floor_2 = 2'b01;
parameter floor_3 = 2'b10;
parameter floor_4 = 2'b11;
/* SET THE PRESENT STATE EQUAL TO THE NEXT STATE */
always @( posedge clock_2Hz or negedge reset) begin
if( reset == 0 ) presentState <= floor_1;
else presentState <= nextState;
end
/* DETERMINE THE NEXT STATE */
always @ (presentState or a or b or c or d) begin
if ( a == 1) direc <=1;
if ( d == 1) direc <=0;
case( presentState )
floor_1: if( a == 1 ) nextState <= floor_2; else rest = 1;
floor_2: begin if ( direc == 1) nextState <= floor_3; if (direc == 0) nextState <= floor_1; if( b == 1 && direc == 1) nextState <= floor_4; else if (b == 1 && direc == 0) nextState <= floor_1; end
floor_3: begin if ( direc == 1) nextState <= floor_4; if (direc == 0) nextState <= floor_2; if( c == 1 && direc == 1) nextState <= floor_4; else if (c == 1 && direc == 0) nextState <= floor_1; end
floor_4: if( d == 1 ) nextState <= floor_3; else rest = 1;
default: nextState <= floor_1;
endcase
end
/* ISSUE COMMANDS TO THE DATAPATH */
floor_1: begin f1 = 1; f2 = 0; f3 = 0; f4 = 0; end
floor_2: begin f1 = 0; f2 = 1; f3 = 0; f4 = 0; end
floor_3: begin f1 = 0; f2 = 0; f3 = 1; f4 = 0; end
floor_4: begin f1 = 0; f2 = 0; f3 = 0; f4 = 1; end
endcase
//if (prefix == 4'b1011) f1 <=1; // this line compiles, but not sure if works overall
//if (prefix == 4'b1011) presentState <= floor_1 ; // this line compiles
//if
end
/* TELLS DATAPATH WHAT TO OUTPUT TO THE SEVSEG */
if ( direc == 1) segout = 7'b1000001;
if ( direc == 0) segout = 7'b1000010;
if ( rest == 1) segout = 7'b1111110;
//if ( f1 == 1 &&) segout = 7'b
//f1 == 1; f2 == 1; f3 == 1; f4 == 1;
//segout = 7'b1111110;
end
endmodule
datapath
module datapath (L1, L2, L3, L4, sevseg, f1, f2, f3, f4, segout, clock_2Hz, reset);
output reg L1, L2, L3, L4;
output reg [0:6] sevseg;
input wire f1, f2, f3, f4, clock_2Hz, reset;
input wire [0:6] segout;
always @ (posedge clock_2Hz or negedge reset) begin
if (reset == 0) begin
sevseg <= 7'b0000001;
L1 <=1;
L2 <=1;
L3 <=1;
L4 <=1;
end
else begin
if( f1 ) L1 <= 1;
if( f2 ) L2 <= 1;
if( f3 ) L3 <= 1;
if( f4 ) L4 <= 1;
sevseg <= segout;
end
end
endmodule
slowclock
module slowclock (clock_2Hz, clock_50MHz, reset);
input wire reset;
input wire clock_50MHz;
output reg clock_2Hz;
reg [26:0] counter_50M;
// Create a 1Hz clock from the 50MHz oscillator that's on the eval board
always @ (posedge clock_50MHz or negedge reset)
if (reset == 1'b0) begin
clock_2Hz <= 0;
counter_50M <= 0;
end
else begin
if (counter_50M == 50000000) begin
counter_50M <= 0;
clock_2Hz <= ~clock_2Hz;
end else begin
counter_50M <= counter_50M + 1;
clock_2Hz <= clock_2Hz;
end
end
endmodule
