Hi ppl
I need some help on a design.
I need to build a voltage controlled current source as well developed as possible.
With this i mean, my requisits are:
--- It should work with frequencies ranging from 100Hz to 20MHz
--- Presenting over that range a THD of about 60dB
--- And the output should be able to give a maximum current bettween [0.5A to 1A].
If you have ideas for this project, places where i can research, sites, components wich could easy the development, post it!!
I´m just starting the research for this, so every idea counts.
best regards
