Buggy/bad code to do serial Tx and PWM
vsmGuy
Advanced Member level 2
VddVss
openusart pic18
I wanted to send out data at 9600 bps, and do variable duty cycle PWM @40Khz.
My PIC18F2550 is clocked @ 20Mhz and here is the code so far:
Code in PICC:
#define _PLIB
#include <htc.h>
//  will automatically include peripheral library header files when --runtime=+plib is used (had to pass this explicitly to the commandline)
#include <pic18.h>
#include <stdio.h>
void
main(void)
	GIE=0;		/* no interrupts are used */
	IPEN=0;
	TRISC=0;	/* PORTC.1 is the output from PWM */
		OpenUSART( USART_TX_INT_OFF &
		USART_RX_INT_OFF &
		USART_ASYNCH_MODE &
		USART_EIGHT_BIT &
		USART_CONT_RX &
		USART_BRGH_HIGH,
		129 );
		This function configures the specified PWM channel for period and for time base.
		PWM uses only Timer2.
		In addition to opening the PWM, Timer2 must also be opened with an OpenTimer2() statement before the PWM will operate.
		period Can be any value from 0x00 to 0xff.
		This value determines the PWM frequency by using the following formula:
		PWM period = [(period) + 1] x 4 x TOSC x TMR2 prescaler		*/
		OpenTimer2(TIMER_INT_OFF & T2_PS_1_1 & T2_POST_1_1);
		OpenPWM2(124);
		SetDCPWM2(0);
		//SetOutputPWM2(SINGLE_OUT, PWM_MODE_1);
	while (1){
		putsUSART("Test\r\n");
	CloseTimer2();
	ClosePWM2();
	CloseUSART();
Code is incorrect as:
1. The first character (first "T") never makes it, but then I seem to get the remaining ones
2. I get no PWM output and for the love of GOD could not figure out how to use SetDCPWM2, and just now, in times of desperation I put in random values, to get no change/no output :-(
Help me :-([/code]
arthur0
Full Member level 2
Stockholm, Sweden
pic18f2550 serial openusart
Well, I must admit I’ve never done PIC before, but a quick inspection of your code makes me have doubts about your calling of OpenUSART and OpenTimer2 functions. Unless you’ve chosen a strange negative logic to define your flags, in my experience I found that the flags are usually OR-ed (or added) and not AND-ed together.
I would think your calls should be:
      OpenUSART( USART_TX_INT_OFF |
      USART_RX_INT_OFF |
      USART_ASYNCH_MODE |
      USART_EIGHT_BIT |
      USART_CONT_RX |
      USART_BRGH_HIGH,
      129 );
and
      OpenTimer2(TIMER_INT_OFF | T2_PS_1_1 | T2_POST_1_1);
(note the vertical bar as in "bitwise OR"; you might use "+" as well).
Does this ring a bell?
Arthur
vsmGuy
VddVss
openusart 9600
Well, we must never forget that:
(A | B) = !(A & B)
Which notation you use depends on how you defined your flags.
It might be that HiTech, in order to make the language more "natural sounding" so that the programmer can read out "I want the UART to have USART_TX_INT_OFF and USART_RX_INT_OFF.. etc" have defined flags in an inverted convention than the normals ones used in the industry.
0010
1000
1010
1101
0111
0101 = !(1010)
As you can see, both are the same and do not have any impact at runtime.
Plus, this portion is stolen from the documentation, so it should not be wrong ;-)
