Dear All :
Does anyone work on Buck or Boost cicruit using behavior method to analysis the stable issue ? WHich method do u use ? Matalb or other method ? Thanks
if u just want an cursoy model , peak current mode ,u can use vccs to replace the switch mos; voltage mode, u can use vcvs to replace the switch mos. if you want more precision model, u can refer to the book <fundementals of power electonics>
