Buck IC Recommendations
Amr Wael
Member level 3
Hello , I am looking for a recommendation for an Adjustable buck converter with an output range of 5 to 15V and an input voltage of 24 V which also supports up to 4 or 5 Amperes. I want to add a digital potentiometer to control the output voltage. I found many ICs including TI tps5450 but when changing the output voltage from 5 to 15 many design elements have to be changed such as the inductor and capacitor values Not only the resistor as I desire.
Do you know any recommended ICs for this purpose? Thank you very much!
KlausST
Super Moderator
Staff member
Read the datasheet thorouhgly, read application notes.
Inductors and capacitors have a "range" not a fixed value. The values are recommendations.
One may optimize for low cost, or low ripple, high efficiency....
Usually datasheet give min and max value informations.
Klaus
Amr Wael
Member level 3
yes indeed after carefully reading the data sheet I found out that I can use higher values than calculated. Thank you
LaTeX Commands Quick-Menu:
