mamech
Full Member level 3
- Joined
- Nov 9, 2010
- Messages
- 176
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,296
- Activity points
- 3,135
hello
I am building currently for the first time a buck converter controlled with a p controller . the problem now is that i notice some weird performance, and I want to ask any expert if what happens is logical or there is something wrong in connections.
I give supply to the circuit around 17 volts, I noticed that the volt at point A in the schematic (voltage at source of mosfet) is round 12 volts, which is really weird to me.
4 volts drop across the mosfet??
the other strange thing, is that the maximum output that I can get at point B on schematic is around 7 volts (which means around 5 volts loss after buck circuit).
so the result, is that for supply of 17 volts, I can control the volt only in range of 0-->7 volts only.
can anyone explain to me why this happens?
