BUCK CONVERTER NEED HELP....!!!
hussain_kiet
Full Member level 5
Karachi, Pakistan
buck vin 150v
hi i am trying to make a buck converter
my specifications are
Vin = 150V Dc
Vout = 24V Dc @ 2A
by now i am doing it with the help of PIC micro controller for PWM generation.
but i don't want to use a controller can anybody suggest a pwm generator IC which can not only generate PWM but can also regulate the voltages to 24V.
thanx in advance..:D
design buck converter with sg3524
You need a triangle wave geneator and a comparator. That means minimum three opamps.
convertisseur 24vdc 150vdc
You can use UC3842/43/44/45/46/47. You can use SG3524/25/26/27. With feedback, you can regulate the output to 24v. Thanks.
