Bt656_4:2:2 format vhdl code
You need to do a sliding average of Cb and Cr during the period. The output needs to be:
Y0
(Cb0+Cb-1)/2
Y1
(Cr0+Cr1)/2
Y2
(Cb2+Cb1)/2
Y3
(Cr2+Cr3)/2
--etc
this also means that you will need a small memory to store 2 pixels (current and past)
You will also need a fifo to get the data across the clock domains as the output will be running 2x input speed.
Thanks buddy.... i m getting the ycbcr format, but now the problem is i m getting only the odd frames not the even frames, i think my problem is the line count of 525, which 3/19/240--- 3 lines for eav, sav format/ 19 lines blanking/ 240 lines ycbcr data(odd frames)
3/20/240--- 3 lines for eav, sav format/ 19 lines blanking/ 240 lines ycbcr data(even frames).. could u suggest me where i m doing mistake., but in some of the datasheets it is given as for NTSC format we have to do 262.5 scan lines... i have no idea regardin this, i m stuck up here.........
I think you mean field, not frame (a frame is made up of two fields).
How is the data you have actually formatted? is it a data stream with embedded TRS codes? or separate VSYNC and HSYNC signals?
