I am currently trying to simulate an output balun for a power amplifier with ADS Momentum. I am having trouble with some ports for the DC-blocking capacitors though. I set up the simulation with a finite ground plane and want to simulate with ports for the blocking caps on both the ground plane and the microstrip line on the unbalanced side of the balun. I defined the ports as differential ports but the log tells me there is a problem at higher frequencies (distance of the pins electrically large). I do know that I normally can define GND reference pins for each pin. However in this certain case what is the best way to define the ports as I do have caps on both sides?
First, you can not use any passive/active component in ADS Momentum EM simulations
Second, what is your intention to use finite ground underneath of the structure ?? Will it be covered by any GND environment ?? ?? Why not infinite ground ??
Third, there are many "close-in" ports, have you ever select calibration mode well ??
If the thickness of the substrate is larger than 1/10 lambda, Momentum will not like it.
There are other consideration too but I suggest you to read carefully Momentum help and if you can find, read some tutorials about it.
I need finitite ground as it is part of the balun. The design is for a Push-Pull PA. The two microstrip line on the right side of the image will be the connections to the drain pins of the transistors and to the left there is the unbalanced output. There will be a cooling block underneatch the amplifier but the part underneath the balun will be cut out. I am not trying to simulate the caps with momentum but want to simulate the structure for Cosimulation with the final design, so I need the ports where the DC-blocking caps will be connected. Calibration mode is set to "none". substrate is 0.508mm with an epr of 3.55. Without the ports for the caps there is no problem. However need to simulate the ports, I just dont know how?
since I want to simulate the S-parameters of the balun later inside a harmonic balance simulation, my max. freq. is 20 GHz (5th harmonic of 4 Ghz, Design frequency 1-4 GHz).
I tried SMD calibration but it does not work in this case because you can not place several SMD-calibrated ports on the same edge of a structure. At least that is what ADS tells me.
