airborncigar
Newbie level 2
1. Does anyone have circuitry for the Microwave freqency changing circuits in a typical Universal lnb?
2Ditto for the channel selection system?
Thankyou Brian.I do not have schematics but the LNB has very little t do with channel selection. All the LNB does is down-convert it's input frequency by around 10GHz so it is low enough to carry along a coaxial cable. The channel selection is done by tuning across the down-converted spectrum and in the case of digital broadcasts, by de-multiplexing as well.
Brian.
From a recent experience here: beware that chaining receivers using the "IF out" or "loop" facility which basically gives a DC blocked copy of the LNB input socket may not isolate the tone signal. I spent ages working out why a spectrum analysis of a satellite downlink was showing wrong frequencies until I realized a receiver down the chain was still managing to switch the LNB to the wrong half of the band!
Brian.
I will answer - it took long enough for me to decide the LNB was faulty and order a new one! Arrgghhh!!!
Brian.
