fadingstar
Newbie level 1
[solved].bot file problem(circuit CAM).
I've get this bot file and my project is to read it and display all the welding plate. when i open it i found it rather readable. but soon a problem pops up.
the first several lines are like this:
G04 Generated by CircuitCAM Version 5.2*
%FSLAX24Y24*%
%MOIN*%
%ADD18R,0.040000X0.100000*%
%ADD19R,0.032000X0.036000*%
%ADD21C,0.040000*%
%ADD22C,0.006000*%
%ADD23C,0.020000*%
%ADD24C,0.015000*%
%ADD26C,0.030000*%
%ADD27C,0.010000*%
%ADD28C,0.012000*%
%ADD29C,0.120000*%
%ADD30C,0.028000*%
%ADD31R,0.019000X0.068000*%
%ADD32R,0.110000X0.045000*%
%ADD66C,0.005000*%
%LNBottomLayer*%
%LPD*%
G54D18*
X97630Y114564D03*
X101630Y114564D03*
X105630Y114564D03*
X106130Y114564D03*
X106630Y114564D03*
lines at beginning are obviously defining some of the plates..D18 to D30. all the lines below that indicate the position and plate Number.
but i can't find any information about D03..or D02,D01 which appears later.
now the weird thing is if i import this file in circuit CAM. it looks normal.
so anyone know where can i get the information about D03?
ps. also.. any one know how does this coordinates work?
ie where is the origin? what is the unit?
thanks very much in advance.
[solved] thanks andre_teprom
that's pretty hardcore.
%FSLAX24Y24*%
%MOIN*%
%ADD21C,0.040000*%
%ADD22C,0.006000*%
%ADD23C,0.020000*%
%ADD24C,0.015000*%
%ADD26C,0.030000*%
%ADD27C,0.010000*%
%ADD28C,0.012000*%
%ADD29C,0.120000*%
%ADD30C,0.028000*%
%ADD66C,0.005000*%
%LNBottomLayer*%
%LPD*%
G54D18*
X97630Y114564D03*
X101630Y114564D03*
X105630Y114564D03*
X106130Y114564D03*
X106630Y114564D03*
