I presume, the exercise problem is referring to circuits that have been previously discussed in the lecture or text book. It's expecting you to turn back and review the respective chapter and design formulas.
HI everyone.
I received this question to do.
My first question is, Is this an normal Emitter follower circuit when the output is take from the Collector? View attachment 140100
Also what do they mean if they say I have to bootstrap this Amplifier without giving me any values for the components?
1.) No - it is NOT an emitter follower (in this case, the output would be at the emitter node).
2.) Do you know the meaning of the "bootstrap" method? This is a specific circuit modification for increasing the input impedance of the amplifier.
I have been through the book a couple of times. Its "electronic devices 9th edition " But I can not find anything resembling that circuit.
@FvM
Yes I have seen a couple of Bootstrap circuits but I dont know how I am suppose to convert one to another?
I know that a cap would be feed back the output into the input and a resistor in applied just before the input signal but I can not see how I can convert it?
If I had some details on component values then sure I can keep currents etc the same.
@FvM
