pls tell the required driver ic for a boost converter of 100khz frequency. i m using STP55NF06 mosfet. i was using MCT2E optocoupler but its not working above 15khz i think. Also attach some ckt for the gate driver if possible
You should clarify the switcher topology. Boost converter is typically using ground referenced MOSFET, can work with a single channel low side driver instead of IR2110.
i have pulse generation circuit. without any microcontroller /microprocessor is it possible? i mean simply pulse generator- driver - mosfet. is there any ckt ?
