Boost circuit simulation problem(Does the crossover frequency of the boost simulation have to be before the peak? )
whr、
Newbie
Newbie level 1
The system I designed has a switching frequency of 50khz, Vin is 12v, and the desired Vo is 24v, which is controlled only by the voltage loop. Then I used Mathcad to put the values of capacitors and inductors into the transfer function expression and formatted the data into MATLAB. By designing the compensator, I adjusted the zero poles to make the crossover frequency around 5khz, when my crossover frequency is after the peak. But when I put the obtained parameters into psim for simulation, I found that the voltage could not be boosted. Below are some of my simulation pictures.
So I tried to use pi to control the voltage loop, and after adjusting the parameters, I found that the voltage could be boosted. I put its transfer function into MATLAB and found that its crossover frequency reached the highest bandwidth speed, was very unstable, its anti-interference ability was too weak, and its response time was also very slow.
But it can still boost the voltage, so I adjusted the zero poles of the type III compensator, and the crossover frequency just reached the peak, which was found to be similar to the effect of pi.
So I want to ask, does the crossover frequency in Boost simulation have to be before the peak? Or is it that single-loop control can only be like this and dual-loop control will improve this situation? Why is its response time so slow?
maybe it´s only me, but I miss a schematic. The schematic of the circuit you simulated.
You posted in the "Elementary electronics section" ... This usually is for qusetions about Ohm´s law and how to calaculate the current limiting resistor for a LED.
If this is "Elementary" for you ... I (don´t) want to see your advanced problems. ;-)
Klaus
LaTeX Commands Quick-Menu:
