BOM gives "field name missing" error!
Rainbow00
Junior Member level 3
table: field name missing
Hi all,
i am using protel DXP 2002. when i try to generate BOM a message box is pop up saying "filed name missing". anybody encountered this before? please do help coz this is drving me crazy. stupid software.
thanks
gd
Added after 28 minutes:
Hi all,
find the answer, hope this will help others in future.
Altium Designer Knowledge Base
Item - 3677
Logged: 1-Apr-2003 Revised: 21-Mar-2004
Topic: PCB Projects - Reports
Applies To: Protel DXP;
Query: The error message Table: Field name missing is displayed when generating a Bill of Materials report
Answer: This will occur when your project contains part parameters with no names. It's OK for a parameter to have a blank value, but not a blank name. Use the Parameter Manager (Tools menu) to locate such parameters, which will be represented as columns with a blank header. You may assign a name to any parameters by right-clicking within the column and choosing Rename.
This has been fixed in Protel 2004
rg
gd
nice! finally, i've found the fix for this error! thanks! :)
