bode plot & stability
keiichi451
how to interprete bode plots
Here is the situation...
I have 4 pole, 2 zero open-loop system. The phase margin is greater than 0 due to the placement of the zeros. However, there are points where the phase goes beyond -180 degrees due to the higher number of poles. Is this system stable when place in closed-loop feedback?
I believe the answer is no, because for some points... gain > 1 and a phase shift of -180 in conjuction with negative feedback will yield positive feedback.
Please advise. Thanks in advance.
flatulent
Advanced Member level 5
Middle Earth
This is a case where the simple bode plot method is hard to interpret. Use the polar plot method and see how many times the locus wraps around -1 +j0. This will give you the number of poles minus the number of zeros in the right half plane.
jiveshgovil
New Delhi
This is also called Nyquist Plot. But it takes time to learn this method and to implement it.
vahidkh6222
Full Member level 2
the easier method is routh-horwitz method i think...
if you have the exact location of poles and zeros of open-looped, then why not calculate the closed-loop transfer function and try this method?
hr_rezaee
Advanced Member level 3
Iran-Mashhad
hi
use root locus plot (rlocus in matlab) and analyse the stability.
easternbean
Newbie level 5
first derive the closed loop transfer function ,the use the matlab instruciton bode to study the stability!
