Board line creation from Gerber in Expedition
raj_pcbtech
Member level 3
India
Hi All,
Could anyone help out to transfer gerber data (draft line) to board outline in Expedition ??
Any help would be gratly appreciated..
Regards,
Rajkumar R
double clik on shape to open properties dialog, slect board outline.
shape should be closed polygon to convert to board outline
Here those lines are showing as a segment. I can not select all segment and change. Could you please give me a useful hint?
Rajkumar
Hold the ctrl key and select the lines whichever you want and then click create polygon from DRAW toolbar.Now you will get a closed polygon.Now you can make that polygon as a Boardoutline.
