BMP280 failing to displays pressure value on lcd screen
bongabobo1
Good day this is my code for bmp280 but its failing to display the value of the pressure
#include <stdint.h>
#if !defined BMP280_I2C1  &&  !defined BMP280_I2C2
#define  BMP280_I2C1
#endif
#if defined BMP280_I2C1  &&  defined BMP280_I2C2
#undef  BMP280_I2C2
#endif
#ifdef  BMP280_I2C1
#define BMP280_Start    I2C1_Start
#define BMP280_Write    I2C1_Wr
#define BMP280_Read     I2C1_Rd
#define BMP280_Stop     I2C1_Stop
#endif
#ifdef  BMP280_I2C2
#define BMP280_Start    I2C2_Start
#define BMP280_Write    I2C2_Wr
#define BMP280_Read     I2C2_Rd
#define BMP280_Stop     I2C2_Stop
#endif
#ifndef BMP280_I2C_ADDRESS
  #define BMP280_I2C_ADDRESS  0xEC
#endif
#define BMP280_CHIP_ID        0x58
#define BMP280_REG_DIG_T1     0x88
#define BMP280_REG_DIG_T2     0x8A
#define BMP280_REG_DIG_T3     0x8C
#define BMP280_REG_DIG_P1     0x8E
#define BMP280_REG_DIG_P2     0x90
#define BMP280_REG_DIG_P3     0x92
#define BMP280_REG_DIG_P4     0x94
#define BMP280_REG_DIG_P5     0x96
#define BMP280_REG_DIG_P6     0x98
#define BMP280_REG_DIG_P7     0x9A
#define BMP280_REG_DIG_P8     0x9C
#define BMP280_REG_DIG_P9     0x9E
#define BMP280_REG_CHIPID     0xD0
#define BMP280_REG_SOFTRESET  0xE0
#define BMP280_REG_STATUS     0xF3
#define BMP280_REG_CONTROL    0xF4
#define BMP280_REG_CONFIG     0xF5
#define BMP280_REG_PRESS_MSB  0xF7
int32_t adc_T, adc_P, t_fine;
// BMP280 sensor modes, register ctrl_meas mode[1:0]
typedef enum
  MODE_SLEEP  = 0x00,  // sleep mode
  MODE_FORCED = 0x01,  // forced mode
  MODE_NORMAL = 0x03   // normal mode
} BMP280_mode;
// oversampling setting. osrs_t[2:0], osrs_p[2:0]
typedef enum
  SAMPLING_SKIPPED = 0x00,  //skipped, output set to 0x80000
  SAMPLING_X1      = 0x01,  // oversampling x1
  SAMPLING_X2      = 0x02,  // oversampling x2
  SAMPLING_X4      = 0x03,  // oversampling x4
  SAMPLING_X8      = 0x04,  // oversampling x8
  SAMPLING_X16     = 0x05   // oversampling x16
} BMP280_sampling;
// filter setting filter[2:0]
typedef enum
  FILTER_OFF = 0x00,  // filter off
  FILTER_2   = 0x01,  // filter coefficient = 2
  FILTER_4   = 0x02,  // filter coefficient = 4
  FILTER_8   = 0x03,  // filter coefficient = 8
  FILTER_16  = 0x04   // filter coefficient = 16
} BMP280_filter;
// standby (inactive) time in ms (used in normal mode), t_sb[2:0]
typedef enum
  STANDBY_0_5   =  0x00,  // standby time = 0.5 ms
  STANDBY_62_5  =  0x01,  // standby time = 62.5 ms
  STANDBY_125   =  0x02,  // standby time = 125 ms
  STANDBY_250   =  0x03,  // standby time = 250 ms
  STANDBY_500   =  0x04,  // standby time = 500 ms
  STANDBY_1000  =  0x05,  // standby time = 1000 ms
  STANDBY_2000  =  0x06,  // standby time = 2000 ms
  STANDBY_4000  =  0x07   // standby time = 4000 ms
} standby_time;
struct
  uint16_t dig_T1;
  int16_t  dig_T2;
  int16_t  dig_T3;
  uint16_t dig_P1;
  int16_t  dig_P2;
  int16_t  dig_P3;
  int16_t  dig_P4;
  int16_t  dig_P5;
  int16_t  dig_P6;
  int16_t  dig_P7;
  int16_t  dig_P8;
  int16_t  dig_P9;
} BMP280_calib;
// writes 1 byte '_data' to register 'reg_addr'
void BMP280_Write8(uint8_t reg_addr, uint8_t _data)
  BMP280_Start();
  BMP280_Write(BMP280_I2C_ADDRESS);
  BMP280_Write(reg_addr);
  BMP280_Write(_data);
  BMP280_Stop();
// reads 8 bits from register 'reg_addr'
uint8_t BMP280_Read8(uint8_t reg_addr)
  uint8_t ret;
  BMP280_Start();
  BMP280_Start();
  BMP280_Write(BMP280_I2C_ADDRESS | 1);
  ret = BMP280_Read(0);
  BMP280_Stop();
  return ret;
// reads 16 bits from register 'reg_addr'
uint16_t BMP280_Read16(uint8_t reg_addr)
  union
    uint8_t  b[2];
    uint16_t w;
  } ret;
  BMP280_Start();
  BMP280_Start();
  ret.b[0] = BMP280_Read(1);
  ret.b[1] = BMP280_Read(0);
  BMP280_Stop();
  return(ret.w);
// BMP280 sensor configuration function
void BMP280_Configure(BMP280_mode mode, BMP280_sampling T_sampling,
                      BMP280_sampling P_sampling, BMP280_filter filter, standby_time standby)
  uint8_t  _ctrl_meas, _config;
  _config = ((standby << 5) | (filter << 2)) & 0xFC;
  _ctrl_meas = (T_sampling << 5) | (P_sampling << 2) | mode;
  BMP280_Write8(BMP280_REG_CONFIG,  _config);
  BMP280_Write8(BMP280_REG_CONTROL, _ctrl_meas);
// initializes the BMP280 sensor, returns 1 if OK and 0 if error
uint8_t BMP280_begin(BMP280_mode mode,
  if(BMP280_Read8(BMP280_REG_CHIPID) != BMP280_CHIP_ID)
    return 0;
  // reset the BMP280 with soft reset
  BMP280_Write8(BMP280_REG_SOFTRESET, 0xB6);
  delay_ms(100);
  // if NVM data are being copied to image registers, wait 100 ms
  while ( (BMP280_Read8(BMP280_REG_STATUS) & 0x01) == 0x01 )
    delay_ms(100);
  BMP280_calib.dig_T1 = BMP280_Read16(BMP280_REG_DIG_T1);
  BMP280_calib.dig_T2 = BMP280_Read16(BMP280_REG_DIG_T2);
  BMP280_calib.dig_T3 = BMP280_Read16(BMP280_REG_DIG_T3);
  BMP280_calib.dig_P1 = BMP280_Read16(BMP280_REG_DIG_P1);
  BMP280_calib.dig_P2 = BMP280_Read16(BMP280_REG_DIG_P2);
  BMP280_calib.dig_P3 = BMP280_Read16(BMP280_REG_DIG_P3);
  BMP280_calib.dig_P4 = BMP280_Read16(BMP280_REG_DIG_P4);
  BMP280_calib.dig_P5 = BMP280_Read16(BMP280_REG_DIG_P5);
  BMP280_calib.dig_P6 = BMP280_Read16(BMP280_REG_DIG_P6);
  BMP280_calib.dig_P7 = BMP280_Read16(BMP280_REG_DIG_P7);
  BMP280_calib.dig_P8 = BMP280_Read16(BMP280_REG_DIG_P8);
  BMP280_calib.dig_P9 = BMP280_Read16(BMP280_REG_DIG_P9);
  BMP280_Configure(mode, T_sampling, P_sampling, filter, standby);
  return 1;
// Takes a new measurement, for forced mode only!
// Returns 1 if ok and 0 if error (sensor is not in sleep mode)
uint8_t BMP280_ForcedMeasurement()
  uint8_t ctrl_meas_reg = BMP280_Read8(BMP280_REG_CONTROL);
  if ( (ctrl_meas_reg & 0x03) != 0x00 )
    return 0;   // sensor is not in sleep mode
  // set sensor to forced mode
  BMP280_Write8(BMP280_REG_CONTROL, ctrl_meas_reg | 1);
  // wait for conversion complete
  while (BMP280_Read8(BMP280_REG_STATUS) & 0x08)
    delay_ms(1);
  return 1;
// read (updates) adc_P, adc_T and adc_H from BMP280 sensor
void BMP280_Update()
  union
    uint8_t  b[4];
    uint32_t dw;
  } ret;
  ret.b[3] = 0x00;
  BMP280_Start();
  BMP280_Write(BMP280_REG_PRESS_MSB);
  BMP280_Start();
  ret.b[2] = BMP280_Read(1);
  ret.b[1] = BMP280_Read(1);
  adc_P = (ret.dw >> 4) & 0xFFFFF;
  ret.b[0] = BMP280_Read(0);
  BMP280_Stop();
  adc_T = (ret.dw >> 4) & 0xFFFFF;
// Reads temperature from BMP280 sensor.
// Temperature is stored in hundredths C (output value of "5123" equals 51.23 DegC).
// Temperature value is saved to *temp, returns 1 if OK and 0 if error.
int8_t BMP280_readTemperature(int32_t *temp)
  int32_t var1, var2, T;
  BMP280_Update();
  // calculate temperature
  var1 = ((((adc_T / 8) - ((int32_t)BMP280_calib.dig_T1 * 2))) *
         ((int32_t)BMP280_calib.dig_T2)) / 2048;
  var2 = (((((adc_T / 16) - ((int32_t)BMP280_calib.dig_T1)) *
         ((adc_T / 16) - ((int32_t)BMP280_calib.dig_T1))) / 4096) *
         ((int32_t)BMP280_calib.dig_T3)) / 16384;
  t_fine = var1 + var2;
  *temp = (t_fine * 5 + 128) / 256;
  return 1;
// Reads pressure from BMP280 sensor.
// Pressure is stored in Pa (output value of "96386" equals 96386 Pa = 963.86 hPa).
// Pressure value is saved to *pres, returns 1 if OK and 0 if error.
uint8_t BMP280_readPressure(uint32_t *pres)
  int32_t var1, var2;
  uint32_t p;
  // calculate pressure
  var1 = (((int32_t)t_fine) / 2) - (int32_t)64000;
  var2 = (((var1/4) * (var1/4)) / 2048 ) * ((int32_t)BMP280_calib.dig_P6);
  var2 = var2 + ((var1 * ((int32_t)BMP280_calib.dig_P5)) * 2);
  var2 = (var2/4) + (((int32_t)BMP280_calib.dig_P4) * 65536);
  var1 = ((((int32_t)BMP280_calib.dig_P3 * (((var1/4) * (var1/4)) / 8192 )) / 8) +
         ((((int32_t)BMP280_calib.dig_P2) * var1)/2)) / 262144;
  var1 =((((32768 + var1)) * ((int32_t)BMP280_calib.dig_P1)) / 32768);
  if (var1 == 0.0)
    return 0; // avoid exception caused by division by zero
  p = (((uint32_t)(((int32_t)1048576) - adc_P) - (var2 / 4096))) * 3125;
  if (p < 0x80000000)
    p = (p * 2) / ((uint32_t)var1);
  else
    p = (p / (uint32_t)var1) * 2;
  var1 = (((int32_t)BMP280_calib.dig_P9) * ((int32_t)(((p/8) * (p/8)) / 8192))) / 4096;
  var2 = (((int32_t)(p/4)) * ((int32_t)BMP280_calib.dig_P8)) / 8192;
  p = (uint32_t)((int32_t)p + ((var1 + var2 + (int32_t)BMP280_calib.dig_P7) / 16));
  *pres = p;
  return 1;
// Lcd pinout settings
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D4 at RB0_bit;
// Pin direction
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D7_Direction at TRISB3_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
  Lcd_Init();
uint32_t Dis;
void Diplay_pressure(uint32_t Dis){
  unsigned char Txt[10];
  delay_ms(50);
  Lcd_Init();          // Initialize LCD
  Lcd_Cmd(_LCD_CLEAR);             // CLEAR display
  Lcd_Cmd(_LCD_CURSOR_OFF);        // Cursor off
  IntToStr(p,Txt);
  Lcd_Out(1,1,Txt);
  Lcd_Out_Cp("hPa");
void main(){
I2C1_Init(100000);
OSCCON=0x00;
TRISC3_BIT=1;          //CLK
TRISC4_BIT=1;          //SDA
ADCON1 = 15;           //All PINS TO digital
SSPCON1=0x28;          // SDA & SCL port serial &clock = fosc/(4*(sspadd+1))
SSPCON2=0x00;
SSPSTAT=0x00;
SSPADD=0x27;           //baud rate 39 in decimal
for(;;){
 BMP280_readPressure(p);
//BMP280_readTemperature(&*temp);
Diplay_pressure(Dis);
  delay_ms(500);
please help!!!!!</stdint.h>
Please add code tags to program listings so the original format is retained.
What doesn't it do? Do you get anything on the display at all?
Brian.
Thanks for your reply .I am new in C language ,what are code tags?
It only displays 4hPa for pressure but for temperature nothing but my code seems to be fine I am not an expect to code review since I am new but I tried to follow the datasheet and other documents.
